netDbMgr process failed to create an internal thread. Thread allocation failures are indicative of a serious resource depletion problem in the underlying Linux Kernel.
Check free memory available on the system using the "show memory" command. If there is sufficient memory try restarting netDbMgr. If the issue persists, on systems with backup nodes try failing over to the backup. Standalone systems may require a reboot to correct the problem.
Error
Failed to create thread name:%name% with error: %errormsg% (%err%)
Name | Type |
name | String |
errormsg | String |
err | sInt32 |
